Fix Unrecognized USB Device? 12 Solutions (2025)
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
How to Fix USB Device Not Recognized
How to Fix USB Device Not Recognized: Complete Troubleshooting Guide
Reading time: 3 minutes
Is your USB device not recognized by Windows? Whether your flash drive isn’t showing up, your computer’s not detecting USB devices, or you’re getting the dreaded “USB device not recognized” error message, this comprehensive guide will help you resolve these common USB connectivity issues.
Understanding USB Device Recognition Issues
When Windows fails to recognize your USB device, you might see one of these symptoms:
  • “USB device not recognized” error message
  • USB drive not showing up in File Explorer
  • Device appears with a yellow exclamation mark in Device Manager
  • Windows 10 not showing USB connected notification
  • Flash drive isn’t detected when plugged in
Common Causes of USB Recognition Problems
  1. Hardware issues (damaged ports or cables)
  2. Driver conflicts or outdated drivers
  3. System configuration problems
  4. Power management settings
  5. Windows update issues
  6. USB controller malfunctions
Quick Fixes for USB Device Not Recognized
1. Basic Hardware Troubleshooting
  1. Try Different USB Ports:
    • Test all available USB ports on your computer
    • Try both USB 2.0 and 3.0 ports (usually blue)
    • Check for physical damage to ports
  2. Check USB Cable:
    • Use a different USB cable
    • Inspect for visible damage
    • Test cable with another device
  3. Test on Another Computer:
    • Connect your USB device to a different computer
    • If it works elsewhere, the issue is with your system
    • If it doesn’t work anywhere, the device may be faulty
2. System Restart Procedure
  1. Remove all USB devices
  2. Shut down your computer completely
  3. Wait 30 seconds
  4. Restart your computer
  5. Reconnect USB devices one at a time
3. Device Manager Solutions
Check Device Status:
  1. Press Windows + X
  2. Select “Device Manager”
  3. Expand “Universal Serial Bus controllers”
  4. Look for devices with warning symbols
  5. Right-click problematic devices
  6. Select “Properties” to view error details
Update USB Drivers:
  1. In Device Manager, find your USB device
  2. Right-click and select “Update driver”
  3. Choose “Search automatically for drivers”
  4. If no updates found, try “Browse my computer for drivers”
  5. Select “Let me pick from a list of available drivers”
Advanced Solutions for USB Recognition Issues
1. Power Management Optimization
Disable USB Selective Suspend:
  1. Open Power Options (Control Panel)
  2. Click “Change plan settings”
  3. Select “Change advanced power settings”
  4. Expand “USB settings”
  5. Disable “USB selective suspend setting”
Adjust USB Root Hub Settings:
  1. Open Device Manager
  2. Expand “Universal Serial Bus controllers”
  3. Right-click each “USB Root Hub”
  4. Select “Properties”
  5. Under “Power Management”
  6. Uncheck “Allow the computer to turn off this device”
2. System File Repairs
Run System File Checker:
sfc /scannow
Use DISM Tool:
DISM /Online /Cleanup-Image /RestoreHealth
3. Registry Fixes
Warning: Back up your registry before making changes:
  1. Open Registry Editor
  2. Navigate to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags
  3. Delete problematic keys
  4. Restart computer
Specialized Solutions
For Flash Drives Not Showing Up:
  1. Check Disk Management:
    • Right-click Start > Disk Management
    • Look for unallocated space
    • Assign drive letter if needed
  2. Update Storage Controllers:
    • Open Device Manager
    • Expand “Storage controllers”
    • Update drivers for all controllers
For External Hard Drives:
  1. Power Supply Check:
    • Ensure adequate power supply
    • Try powered USB hub
    • Test with original power adapter
  2. Partition Verification:
    • Use Disk Management
    • Check for corrupted partitions
    • Attempt partition recovery if needed
Preventive Measures
1. USB Device Care:
  • Always use “Safely Remove Hardware” feature
  • Keep devices clean and protected
  • Avoid physical damage to ports and cables
2. System Maintenance:
  • Regular Windows Updates
  • Driver updates
  • System cleanup
3. Backup Procedures:
  • Regular data backups
  • Multiple storage solutions
  • Cloud backup options
When Nothing Works
Data Recovery Options:
  1. Use professional recovery software
  2. Consider professional service
  3. Contact device manufacturer
Hardware Replacement:
  • When to replace USB devices
  • Choosing reliable replacements
  • Warranty considerations
Professional Support Options
When to Seek Help:
  • Hardware damage
  • Data loss situations
  • Complex system issues
Support Resources:
  • Microsoft Support
  • Device manufacturer support
  • Professional IT services
Final Troubleshooting Checklist
□ Tested multiple USB ports
□ Verified cable condition
□ Updated system and drivers
□ Checked power management
□ Ran system file repairs
□ Verified device in other systems
□ Documented error messages
□ Backed up important data
Remember: Always start with the simplest solutions before moving to more complex fixes, and create backups of important data before attempting any system-level changes.
About the Author
Linsey Knerl is a contributing writer for HP® Tech Takes. Linsey is a Midwest-based author, public speaker, and member of the ASJA. She has a passion for helping consumers and small business owners do more with their resources via the latest tech solutions.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
