HP Device Not Charging? Complete Troubleshooting Guide | HP® Tech Takes
HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HP Poly Headphones, sunglasses, and an HP laptop sitting on a wooden desk charging with a yellow object blurred in the background.
Complete HP Laptop & Accessory Charging Troubleshooting Guide
Ant Koksal
Reading time: 9 minutes
This comprehensive guide covers 7 proven solutions to fix charging issues with HP laptops and wireless accessories. Most problems can be resolved in under 15 minutes using these DIY methods.
HP portable devices make our lives easier, but for that to happen, their batteries need to be fully charged and working smoothly. Whether you use an HP laptop or any type of HP wireless accessory, charging problems can complicate both your daily and professional life. What makes this issue particularly frustrating is that there are many possible causes: from a faulty battery to a loose power cable, many things can lead to HP device charging problems.
This HP wireless accessory & laptop charging troubleshooting guide will help you:
  • Identify the most common causes of "HP laptop not charging" problems
  • Apply DIY solutions for HP device charging issues
  • Determine when to seek professional help if your HP laptop battery is not charging
  • Contact HP customer support for charging-related problems
Quick Diagnosis: Identifying Your Charging Problem
Typical charging time: HP laptops usually take between 1.5 and 2.5 hours to reach 100% charge. However, sometimes due to hardware, software, or user error, it may not be possible to charge your battery. To answer the question "Why is my laptop not charging?", you need to follow certain steps, the first of which is a visual inspection.
Most common causes:
  • Faulty power adapter (40% of cases)
  • Damaged charging cable (30% of cases)
  • Battery degradation (20% of cases)
  • Software/driver issues (10% of cases)
Safety Considerations Before Troubleshooting
Safety Call-Out Box
IMPORTANT:
During both the visual inspection and the other steps explained below, make sure your device is unplugged and turned off. This is necessary for your safety and is especially important if you are trying to fix laptop power adapter problems. If you are unsure of what you are doing or are concerned about damaging your device, it is best to seek professional help.
Step 1: Visual Inspection (Takes 2 Minutes)
Visual inspection is the first and most important step in diagnosing charging problems.
Check Power Connections
  1. Check whether the charger is plugged into both the device and the power outlet. Start at the outlet and follow the cable to the device.
  2. At the same time, examine the power cable. Make sure there are no breaks or unusual bends.
  3. When you reach the device, check that the cable is plugged into the correct port. You may have plugged it into the wrong USB-C port.
HP USB-C Critical Detail
Critical Detail:
Some HP laptop models have 2 USB-C ports, one for data transfer and the other for charging. If the charger cable is plugged into the data transfer port, your device will not charge. Also, it would be a good idea to try plugging the power cord into a different outlet before continuing.
Step 2: Hard Reset (Takes 3 Minutes)
This fixes 60% of HP laptop charging issues and should be your first troubleshooting step after visual inspection.
Complete Hard Reset Procedure
  1. Shut down your HP laptop and unplug it from the power outlet
  2. Disconnect all nonessential devices (e.g., USB flash drive, external HDD) connected to your HP laptop
  3. Remove the AC adapter from your laptop
  4. Press and hold the power button on the device for approximately 25 seconds
  5. Reconnect the AC adapter to your device and turn on the computer
  6. Check to see if the problem has been resolved
If the hard reset hasn't resolved the issue, it's time to start performing software and hardware checks.
Step 3: Battery Health Diagnostics (Takes 5-10 Minutes)
You can perform battery health diagnostics in two different ways, both providing valuable insights into your battery's condition.
Method 1: Windows Built-in Battery Report
  1. Click the Windows Start button, find the "Command Prompt" option, right-click it, and select "Run as Administrator"
  2. Type the following in the window that opens and click the Enter button: powercfg /batteryreport
  3. The report prepared about your battery will be saved in the User folder
By opening the report, you can see the current status of your battery compared to its design capacity. This will give you a good idea of whether it is time to replace the battery. For example, if its capacity has fallen below 50%, you should consider replacing it.
Method 2: HP Battery Health Check Utility
To check battery health, you can also use the HP Battery Health Check Utility. This tool runs automatically and displays a failure ID code if it detects a problem. With this code, you can request repairs from an authorized service center.
Step 4: Port Cleaning & Connection Fixes (Takes 3-5 Minutes)
Connection issues are often overlooked but can be the root cause of charging problems.
Try Alternative Charging Methods
Inspect and Clean Charging Port
  1. Examine your device's charging port and check for any problems. For example, it may be damaged or something may be stuck inside it.
  2. Use a soft, dry cloth to clean the charging contacts
  3. Make sure the charging points are completely dry before reconnecting the cable
Power Adapter Verification
Make sure you are using the correct power adapter. If the problem is with the adapter, you can simply order a new one. Using an incompatible adapter can prevent proper charging and may damage your device.
Step 5: Software & Driver Updates (Takes 5-10 Minutes)
Before attempting advanced solutions, it is a good idea to check if there is an update for the operating system's battery drivers and power management.
Update Battery Drivers
  1. Right-click on the Windows Start button and select "Device Manager"
  2. Find the "Batteries" option on the screen that opens and right-click on the hardware listed as "Microsoft ACPI Compliant Control Method Battery"
  3. Click on "Update Driver"
If a new driver is available, Microsoft Windows will automatically download and install it. Restart your computer and see if the problem persists.
Additional driver updates to consider:
  • Power management drivers
  • Chipset drivers
  • BIOS updates (advanced users only)
HP Wireless Accessories Charging Issues
If you are experiencing charging issues with an HP wireless accessory, the solutions you should try will vary depending on the type of accessory.
HP Wireless Headphones Charging Solutions
A wired headphone does not need to be charged. If you are using a wireless headphone, first check the charging cable and make sure that there is no problem with the cable and that it is plugged into the correct port.
Detailed troubleshooting steps:
  1. Try plugging the wireless headphone's charging cable into a different port on your device. For example, if you have two USB-C ports, you can try the cable in both of them.
  2. Clean the charging points on your headphones using a soft, dry cloth. Before reconnecting the charging cable, make sure these points are dry.
  3. Check for firmware updates for your specific headphone model
  4. Test with a different charging cable if available
  5. Verify the headphones are properly seated in their charging case (if applicable)
HP Mouse and Keyboard Charging Troubleshooting
Most HP wireless keyboards and mice use external batteries and do not need to be charged. For example, the HP 460 wireless keyboard runs on 2 AAA batteries, and if it is not working, it may simply be because the batteries are dead: installing new AAA batteries will quickly resolve the issue.
For rechargeable HP peripherals:
  1. Try plugging the charging cable into a different port on your device
  2. Clean the charging points as explained above
  3. Check the charging indicator lights to verify charging status
  4. Test with a different USB cable if your device supports it
  5. Verify power management settings aren't interfering with charging
USB Receiver and Connectivity Issues
Sometimes, the problem is not related to charging: your HP accessory may appear to be malfunctioning due to connection issues, even though it is charging. Be sure to check the USB/Bluetooth dongle that enables the accessory to communicate wirelessly with your computer, and try plugging it into different ports. Also, check for driver updates for your accessory: you can do this using the official HP Software and Drivers website.
Additional connectivity troubleshooting:
  • Try pairing the device again if using Bluetooth
  • Check for interference from other wireless devices
  • Verify the accessory is within proper range of the receiver
  • Reset the accessory according to manufacturer instructions
Advanced Troubleshooting: Battery Replacement
If your HP laptop “not charging” problem is caused by your battery rather than the power cable, replacing it may solve the problem.
User-Replaceable Battery (External Battery Models)
To replace a user-accessible battery:
  1. Purchase an HP replacement battery (make sure it is compatible with your device)
  2. Turn off your HP laptop and unplug it from the power outlet
  3. Turn your HP laptop upside down and remove the back panel
  4. Remove your current battery and carefully disconnect it from the motherboard
  5. Insert the new battery in place of the old one and connect it to the motherboard
  6. Reattach the back panel and turn on your laptop
HP Battery Replacement Note
Important Note:
Keep in mind that laptop battery replacement by user is only available for HP laptops that do not have an internal battery.
Internal Battery Replacement
If your battery is internal, you cannot replace it yourself: this must be done by a professional HP technician. Attempting to replace an internal battery can void your warranty and potentially damage your device.
Signs you need professional battery replacement:
  • Battery capacity below 50% of original
  • Rapid battery drain
  • Battery not holding charge
  • Physical swelling or damage to battery
  • Overheating during charging
When to Contact HP Customer Support & Warranty Coverage
If none of the suggestions we have shared here have worked and/or you have an internal battery that needs to be replaced, it is time to seek professional help.
HP Warranty Coverage Details
The HP standard warranty is valid for 1-3 years unless you have purchased a care pack or extended warranty, and covers all parts of your computer and accessories, including your battery. However, please note that accidental damage, user error, hardware wear and tear, unauthorized repairs and replacements are not covered by the warranty.
You can use the HP Warranty Check Tool to check the current status of your warranty.
When Professional Help is Needed
  • All DIY solutions have failed
  • Internal battery replacement is required
  • Hardware damage is suspected
  • Device is still under warranty
  • You're uncomfortable performing troubleshooting steps
  • The problem involves multiple components
Getting Warranty Service
If your warranty is still valid and your battery is covered, it may be possible to have it repaired and/or replaced free of charge at your nearest HP Authorized Service Center.
What to bring to service:
  • Proof of purchase
  • Device serial number
  • Detailed description of the problem
  • List of troubleshooting steps already attempted
Preventive Maintenance Tips: Extend Battery Life
Remember that you can extend the life of your battery and make it work more efficiently with a few simple precautions and settings:
Power Management Settings
  • Set the Power Option to "Power Saver" or "HP Recommended"
  • Reduce screen brightness and minimize the number of open applications
  • Disable unnecessary startup programs
  • Turn off Wi-Fi and Bluetooth when not in use
  • Use sleep mode instead of leaving laptop on
Physical Care and Environment
  • Consider using a cooling pad to prevent overheating
  • Keep your laptop in a cool, dry environment
  • Avoid extreme temperatures (both hot and cold)
  • Don't leave your laptop in direct sunlight
  • Store in a well-ventilated area
Battery Charging Best Practices
  • Try to keep the battery level between 20% and 80%
  • Avoid letting the battery completely drain regularly
  • Don't keep the laptop plugged in 24/7
  • Perform a full discharge/charge cycle monthly
  • Unplug the charger when battery reaches 100%
Regular Maintenance
  • Clean vents and fans regularly to prevent overheating
  • Update drivers and BIOS regularly
  • Run battery health checks monthly
  • Keep your operating system updated
  • Use genuine HP accessories and chargers
Quick Reference: Complete Troubleshooting Checklist
Follow this checklist in order for best results:
✓ Safety first: Unplug and turn off device
✓ Visual inspection: Check cables, ports, and connections (2 min)
✓ Hard reset: Power button hold for 25 seconds (3 min)
✓ Battery health check: Run diagnostics (5-10 min)
✓ Port cleaning: Clean charging contacts (3-5 min)
✓ Driver updates: Update battery and power drivers (5-10 min)
✓ Alternative charging: Try different cables/adapters
✓ Professional help: Contact HP support if issues persist
Most HP laptop charging issues resolve within 15 minutes using these methods. Complex hardware problems may require professional diagnosis and repair.
HP Customer Support Is Ready to Help You
If you are experiencing a charging problem with your HP laptop or accessory, start with a visual inspection of the power cable, continue with a hard reset, and use tools that diagnose battery health. Check for software and driver updates, clean the charging points, and make sure the problem is not caused by the connection.
If the problem persists despite all these steps, contact official HP Customer Support: you can count on us to help you. To benefit from HP warranty for a longer period of time, consider purchasing a care pack or extended warranty!
Contact options:
  • HP Online Support for chat and email assistance
  • HP Phone Support for direct technical help
  • HP Authorized Service Centers for in-person repairs
  • HP Community Forums for peer support and solutions
About the Author
Ant Koksal began writing about the PC gaming & tech industry after a long-term career as a lawyer and has over fifteen years of experience in both. He worked as a writer and editor in magazines such as Electronic Gaming Monthly and Level.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
