HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
How to Know the Differences Between an LED Display and LCD Monitor
LED vs LCD Monitors: Key Differences Explained
Zach Cabading
Reading time: 7 minutes
When shopping for a new monitor, you’ll often encounter the terms LCD and LED. But what exactly are the differences between LCD and LED monitors? Is one better than the other for certain activities like gaming or graphic design? In this article, we’ll break down the key distinctions between LCD and LED displays to help you make an informed decision.
What’s the Difference Between LCD and LED?
The main difference between LCD (Liquid Crystal Display) and LED (Light Emitting Diode) monitors lies in their backlighting technology:
  1. LCD monitors use cold cathode fluorescent lamps (CCFLs) for backlighting.
  2. LED monitors use light-emitting diodes for backlighting.
It’s important to note that all LED monitors are actually a type of LCD monitor. The term “LED monitor” is shorthand for “LED-backlit LCD monitor.”
What Does LCD Stand For?
LCD stands for Liquid Crystal Display. This technology uses liquid crystals, which are substances with properties of both liquids and solids, to create images on a screen. When an electric current is applied, the liquid crystals align to allow or block light, creating the images you see on the display.
What Is an LCD Monitor?
An LCD monitor is a flat-panel display that uses liquid crystal technology to produce images. Key characteristics of LCD monitors include:
  1. Use of liquid crystals to control light passage
  2. Backlight (usually cold cathode fluorescent lamps (CCFLs)) to illuminate the screen
  3. Typically thinner and more energy-efficient than older CRT monitors
  4. Good color reproduction and brightness
What Is an LED Monitor?
An LED monitor is a type of LCD monitor that uses Light Emitting Diodes (LEDs) for backlighting instead of traditional fluorescent lights. Key features of LED monitors include:
  1. Use of LED backlighting technology, making it a superior LED display with easier maintenance, better color accuracy, and improved visual clarity
  2. Often thinner and more energy-efficient than standard LCD monitors
  3. Better contrast ratios and color accuracy
  4. Longer lifespan compared to traditional LCD monitors
How LCD Technology Works
To understand the differences, let’s explore how LCD technology functions:
  1. Liquid crystals: These are substances with properties of both liquids and solids. When exposed to electricity, their molecular structure changes.
  2. Pixels: Each pixel on an LCD screen consists of three subpixels (red, green, and blue).
  3. Backlighting: Light passes through the liquid crystals and color filters to create the image you see on LCD screens.
Types of LED Backlighting
LED monitors use two main types of backlighting:
  1. Full-array backlighting: LEDs are placed evenly across the entire screen, allowing for local dimming and better contrast.
  2. Edge lighting: LEDs are placed along the edges of the screen, resulting in thinner displays but potentially less uniform lighting.
LCD vs LED: Key Comparisons
Here’s a quick comparison of LCD and LED monitors: When considering a 4K lcd display, it's important to note the differences in resolution, color accuracy, and intended use. LCD displays utilize liquid crystals and backlighting to produce images, offering advantages in energy efficiency and budget segments, but they may have trade-offs in picture quality compared to LED technology.
Feature LCD LED
Backlighting CCFL Light Emitting Diodes
Energy Efficiency Good Better
Contrast Ratio Good Excellent
Color Accuracy Good Better
Lifespan Average Longer
Thickness Thicker Thinner
Price More Affordable Generally Higher
1. Picture Quality
LED monitors, especially those with full-array backlighting, generally offer superior picture quality with better contrast ratios and deeper blacks compared to an LCD display.
LCD monitors can still provide good image quality but may struggle with producing true blacks.
2. Energy Efficiency
  • LED monitors are typically more energy-efficient than traditional LCD monitors.
  • This can result in lower power consumption and reduced electricity bills over time.
3. Lifespan
  • LED monitors often have a longer lifespan compared to LCD monitors due to their more durable backlighting technology.
  • LED backlights typically last 50,000 to 100,000 hours, while CCFL backlights in traditional LCDs last around 30,000 to 60,000 hours.
4. Viewing Angles
  • LED monitors, particularly those using IPS (In-Plane Switching) technology, tend to offer wider viewing angles than traditional LCD monitors.
  • This means colors and contrast remain more consistent when viewing the screen from different angles.
5. Price
  • LCD monitors are generally less expensive than LED monitors.
  • However, the price gap has narrowed in recent years as LED technology has become more common.
Is LCD or LED Better for Gaming?
For gaming, full-array LED monitors are usually the better choice due to:
  1. Higher contrast ratios
  2. Better color accuracy
  3. Faster response times (important for reducing motion blur)
  4. Local dimming capabilities for improved dark scene performance
However, if you’re on a budget, a high-quality LCD monitor can still provide a good gaming experience, especially if it has a high refresh rate. LCD screens, despite some limitations compared to LED technology, remain a common choice for traditional computing and can be suitable for gaming with the right specifications.
Response Time and Refresh Rate
When choosing a gaming monitor, consider these factors:
  • Response time: LED monitors typically have faster response times, reducing motion blur and ghosting.
  • Refresh rate: Both LCD and LED monitors can offer high refresh rates (e.g., 144Hz or 240Hz), which is crucial for smooth gameplay.
Is LED or LCD More Energy Efficient?
LED monitors are generally more energy-efficient than LCD monitors. Here’s why:
  1. LEDs require less power to produce the same level of brightness
  2. LED backlighting allows for more precise control over screen brightness
  3. LED monitors often have better power management features
  4. The energy savings of LED monitors can lead to lower electricity bills over time
On average, LED monitors consume about 20-30% less power than their LCD counterparts.
Why Is LCD Better Than LED in Some Cases?
While LED monitors have many advantages, LCD displays can be better in certain situations:
  1. Cost: LCD monitors are often more affordable, making them a good choice for budget-conscious buyers
  2. Matte screens: Many LCD monitors come with matte screens, which are better at reducing glare in bright environments
  3. Consistent lighting: Traditional LCDs often have more uniform backlighting across the entire screen
  4. Less blue light: Some users find that LCD monitors emit less blue light, potentially reducing eye strain
LCD vs LED for Eye Comfort
Both LCD and LED monitors can cause eye strain with prolonged use. However, LED monitors often have some advantages:
  1. Better brightness control
  2. Reduced flicker (especially in higher-end models)
  3. Blue light filtering options in many newer LED monitors
To reduce eye strain, regardless of monitor type:
  • Follow the 20-20-20 rule: Every 20 minutes, look at something 20 feet away for 20 seconds.
  • Adjust your monitor’s brightness and contrast settings to comfortable levels.
  • Use proper lighting in your workspace to reduce glare.
Color Accuracy: LED vs LCD
Color accuracy is crucial for professionals in graphic design, photo editing, and video production. Here’s how LED and LCD monitors compare:
  • LED monitors generally offer better color accuracy due to their wider color gamut.
  • High-end LED monitors can display a larger percentage of the sRGB and Adobe RGB color spaces.
  • Some professional-grade LCD monitors still offer excellent color accuracy, especially those with IPS panels.
Future Display Technologies: OLED and QLED
While LCD and LED monitors dominate the current market, emerging technologies are worth keeping an eye on:
  1. OLED (Organic Light Emitting Diode):
    • Offers perfect blacks and excellent contrast ratios
    • Each pixel emits its own light, allowing for true blacks and infinite contrast
    • Can be expensive and may be susceptible to burn-in
2. QLED (Quantum Dot LED):
  • Provides enhanced color accuracy and brightness compared to traditional LED displays
  • Uses quantum dots to improve color reproduction
  • Offers better brightness and longevity compared to OLED
Choosing Between LCD and LED Monitors
When deciding between LCD and LED monitors, consider the following factors:
  1. Purpose: What will you primarily use the monitor for (e.g., general use, gaming, professional work)? LCD screens are often sufficient for traditional computing tasks.
  2. Budget: LED monitors are generally more expensive but offer better performance.
  3. Energy efficiency: If power consumption is a concern, LED monitors are the better choice.
  4. Picture quality: For the best image quality, especially in dark scenes, choose an LED monitor with full-array backlighting.
  5. Screen size: Both LCD and LED technologies are available in various sizes, but LED might offer more options for larger screens.
Conclusion
When choosing between LCD and LED monitors, consider your specific needs:
  • For general use and office work, both LCD and LED monitors can perform well.
  • For gaming, graphic design, or video editing, an LED monitor (preferably with full-array backlighting) is often the better choice due to superior picture quality and color accuracy.
  • If energy efficiency and a longer lifespan are priorities, LED monitors have the edge.
  • For those on a tight budget, LCD monitors still offer good value and performance.
Ultimately, the best monitor for you depends on your specific requirements, budget, and intended use. By understanding the differences between LCD and LED technologies, you can make an informed decision that best suits your needs.
Remember that display technology is constantly evolving, and what’s considered top-of-the-line today may be surpassed by new innovations in the future. Always consider the latest developments and reviews when making your final decision.
About the Author
Zach Cabading is a contributing writer for HP® Tech Takes. Zach is a content creation specialist based in Southern California, and creates a variety of content for the tech industry.
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
