You depend on your laptop’s battery to keep you productive throughout the day. But what happens when you plug in your charger and nothing happens? A
laptop that won’t charge can be incredibly frustrating, but don’t panic just yet. In this guide, we’ll explore common reasons why your laptop battery isn’t charging and provide 8 practical solutions to get your device up and running again.
Common Reasons Why Your Laptop Won’t Charge
Before diving into solutions, it’s helpful to understand why your laptop might not be charging. Here are the three most common culprits:
- Power cord and adapter issues
- Software malfunction
- Declining battery health
1. Power Cord and Adapter Issues
Your
laptop charger endures a lot of wear and tear from daily use. Frequent bending and wrapping can damage the cord over time. If your PC’s charging light doesn’t illuminate when plugged in, you may have a faulty or damaged cord. Always ensure that the power cable is securely connected to both the laptop and the wall outlet.
2. Software Malfunction
While
Windows 10 is generally good at self-maintenance, sometimes settings or outdated
drivers can cause charging issues. For example, your computer’s power settings might be configured to shut down at a low battery level or enter sleep mode quickly.
3. Declining Battery Health
Like all technology, laptop batteries have a limited lifespan. If your laptop has been:
- Overheating while charging
- Losing charge quickly
- Taking longer to fully charge
These are signs that your battery may be reaching the end of its life.
How to Check Your Laptop’s Battery Health
Before troubleshooting, it’s a good idea to check your battery’s health status:
- Click on the battery icon in the taskbar
- Select “Battery settings”
- Under “Battery health,” you’ll see information about your battery’s condition
This can provide crucial information about your battery’s status and any potential power-related issues.
8 Solutions to Fix a Laptop That Won’t Charge
Now that we understand the potential causes, let’s explore 8 ways to fix a laptop battery that’s not charging:
1. Check Your Connections
It may seem obvious, but always start by ensuring everything is properly plugged in. Check each connection point:
- Wall outlet to AC adapter
- AC adapter to laptop port
- Battery seated correctly (if removable)
Also, test a different wall outlet or reset your surge protector to rule out power source issues.
2. Verify You’re Using the Correct Charging Port
Many modern laptops, especially those with USB-C ports, may have multiple ports with different functions. Make sure you’re using the designated charging port, not a data-transfer port.
3. Remove the Battery (If Possible)
For laptops with removable batteries:
- Remove the battery
- Hold the power button for 15 seconds
- Plug in the charger
- Power on the laptop
If it turns on, the issue likely lies with the battery, not the charger.
4. Inspect Your Power Cords and Adapter
Carefully examine your power cords for any visible damage, unusual bends, or fraying. Check the power jack to ensure a solid connection. A faulty or loose power jack could indicate hardware issues that may require repairs. If you find any issues, you may need to replace the affected cord or adapter.
5. Update Your Drivers
Outdated drivers can sometimes cause charging issues. To update your battery drivers in Windows 10:
- Right-click the Start menu and select “Device Manager”
- Expand the “Batteries” section
- Right-click “Microsoft ACPI Compliant Control Method Battery”
- Choose “Update Driver”
6. Clean Your Charging Port
Dust and debris in your laptop’s charging port can prevent a proper connection. Carefully clean the port using compressed air or a soft brush.
7. Allow Your Laptop to Cool Down
Overheating can cause your laptop to stop charging as a safety precaution. If your device feels hot:
- Unplug it
- Place it on a cool, flat surface
- Allow it to cool completely before attempting to charge again
8. Seek Professional Help
If none of the above solutions work, it may be time to consult a professional. For Mac users, consider resetting the System Management Controller (SMC) as it can resolve power-related issues. Contact your laptop manufacturer’s support team or visit a reputable
computer repair shop for further diagnosis and repair.
HP Laptops with Reliable Battery Performance
HP Spectre laptops are designed for exceptional battery life and charging reliability:
- Fast charge technology: Get up to 50% battery in just 30 minutes
- Long-lasting battery: Up to 22 hours of use on a single charge
- HP Battery Health Manager: Optimizes battery performance and longevity
By following these troubleshooting steps and considering a laptop with robust battery features, you can minimize charging issues and stay productive wherever you go. Remember, if you’re consistently experiencing charging problems, it may be time to consider a battery replacement or upgrade to a new laptop with improved battery technology.
About the Author
Linsey Knerl is a contributing writer for HP® Tech Takes. Linsey is a Midwest-based author, public speaker, and member of the ASJA. She has a passion for helping consumers and small business owners do more with their resources via the latest tech solutions.
