Key Takeaways:
- Connecting an HP Smart Tank printer to Wi-Fi is quick, and users can receive guidance in the app.
- Most printer models are designed for simple setup through the HP Smart app.
- Most printer Wi-Fi connection issues can be resolved with basic troubleshooting, like resetting network settings or checking signal strength.
To connect your HP Smart Tank printer to Wi-Fi, download the HP Smart app and put the printer into wireless setup mode, then follow the in-app instructions to select your network and enter your password. Most Smart Tank models can connect in less than five minutes. For a password-free option, WPS allows you to auto-connect by holding down the wireless button on the printer and pressing the WPS button on your router.
Connecting your HP Smart Tank printer to Wi-Fi and enabling wireless printing lets you print from laptops, smartphones, or tablets without cables. HP Smart Tank printers are user-friendly. Whether you're using a basic home model or a more advanced printer, the process can typically be guided through the HP Smart app.
How To Connect HP Smart Tank 5101 To Wi-Fi
The HP Smart Tank 5101 offers a straightforward setup process similar to the HP Smart Tank 5103. After placing the printer in setup mode, open the HP Smart app and follow the instructions.
As an alternative, Wi-Fi Protected Setup (WPS) can be used to connect the printer to your network without entering a password manually. This requires pressing and holding the "wireless" button for 3 seconds until it starts blinking, then pressing the WPS button on your router to auto-connect. Once connected, you will see a blue light solid on, and then you can open the app and add the printer that is already connected to WiFi.
How To Connect HP Smart Tank 5103 To Wi-Fi
To connect the HP Smart Tank 5103, start by putting the printer into
Wi-Fi setup mode. This is usually done by:
- Pressing and holding the "information" button until all lights are on
- Pressing the "wireless" and "cancel" buttons together for three seconds, until the Wi-Fi icon starts cycling and the blue light starts blinking, indicating that the printer is ready to connect.
Next, open the HP Smart app on your device. The app will automatically detect the printer and guide you through the setup process. You will select your Wi-Fi network and enter your password to complete the connection.
If you encounter issues, the HP Smart app also provides helpful troubleshooting prompts. Once connected, you can print, scan, and monitor ink levels directly from your device.
How To Connect HP Smart Tank 6001 To Wi-Fi
The HP Smart Tank 6001 follows a similar setup process but includes enhanced wireless stability for home office use. Begin by entering wireless setup mode. Using the HP Smart app, select your network and complete the connection.
If the blue light continues blinking, it could indicate a connection issue. Restarting the printer and router usually resolves this. The HP Smart Tank 6001 also pushes automatic firmware updates and supports
dual-band networks.
How To Connect HP Smart Tank 7001 To Wi-Fi
The HP Smart Tank 7001 can be connected using the app as a guide. Start by entering wireless setup mode, then open the HP Smart app to complete the connection.
If the printer has been previously connected to another network, you may need to reset the network settings. Understanding the indicator lights can help troubleshoot issues.
For example, a blinking blue light typically means the printer is either not connected to Wi-Fi yet or is in Wi-Fi setup mode, while a solid light indicates a successful connection. This model also supports wireless and
mobile printing, making it ideal for home office users.
How To Connect HP Smart Tank 7301 To Wi-Fi
For the HP Smart Tank 7301, access the wireless settings, choose your network, and enter your password to connect.
This model also allows you to switch between networks easily, which is useful in dynamic work environments. It supports both traditional Wi-Fi connections and
Wi-Fi Direct, enabling direct device-to-printer communication without a network.
If the printer appears offline, reconnecting through the HP Smart app or restarting the network can often resolve the issue.
How To Connect HP Smart Tank 7602 To Wi-Fi
The HP Smart Tank 7602 features a touchscreen display that simplifies Wi-Fi setup. Navigate to the wireless settings on the screen and select your network. Enter your password on the display to connect.
This model is designed to work well with
mesh networks, making it a good choice for larger homes or offices. If you experience connectivity issues, troubleshooting options are available on the touchscreen display and in the HP Smart app.
With business-grade wireless reliability, the HP Smart Tank 7602 supports features like scan-to-cloud and remote management. Automatic updates ensure the printer remains secure and performs properly.
How To Get Your HP Smart Tank Printer Back Online
If your printer goes offline, start by restarting both the printer and your router. This often resolves temporary issues. Check your Wi-Fi signal strength to ensure the printer is within range of the router. Weak signals can cause connectivity problems.
Reconnecting the printer through the
HP Smart app can also help reestablish the connection.
Make sure the printer is set as the default device on your computer. Clearing the print queue can resolve issues caused by stuck printing jobs, and updating firmware and drivers ensures network compatibility.
The Wrap-Up
Wireless printing eases one of the most common friction points in a home or office setup: the need to be physically tethered to your printer.
Once your HP Smart Tank is connected to Wi-Fi, you can print from any device on your network, whether it’s a laptop in another room or a smartphone while you’re working remotely through the HP Smart app.
The setup process is consistent across the Smart Tank lineup, and most models walk you through it in minutes via the HP Smart app. Features like WPS auto-connect, self-healing Wi-Fi on the 7301 and 7602, and touchscreen-guided setup on the 7602 also mean there's usually a straightforward path regardless of your technical comfort level.
If something does go wrong, whether it’s a dropped connection or a network change, the troubleshooting steps in this guide can help resolve most common issues. When you’re ready to get set up, explore the full
HP Smart Tank lineup or
get in touch with HP support if you need a hand.
FAQs
How do you change the Wi-Fi network on your HP Smart Tank printer?
To change the Wi-Fi network, start by resetting the printer’s wireless settings. This puts the printer back into setup mode. Then open the HP Smart app and select the new network. Enter the new password and complete the setup process, then confirm the connection through the app.
How do you connect an HP Smart Tank printer to your Wi-Fi network?
Download the HP Smart app and put the printer into Wi-Fi setup mode, then select your network and enter your password. The app will guide you through the installation process.
Which HP printers can connect to your wireless network?
Most modern HP printers, including DeskJet, ENVY, OfficeJet, and Smart Tank models, support wireless connectivity. These printers are designed to work with home and office networks.
Wi-Fi Direct is also available on many models, allowing direct connections
without a router. Checking the product specifications is the best way to confirm compatibility.
Do all printers connect to Wi-Fi?
Not all printers have wireless capability. Some older or basic models rely on USB connections only. To determine if a printer supports Wi-Fi, check the specifications or look for wireless indicators on the device.
How do I reset the Wi-Fi on my HP Smart Tank printer?
To reset the network settings on your HP Smart Tank printer, select the Wireless button or icon on your printer. Then, press and hold the Wireless and Cancel buttons at the same time for about five seconds, until the wireless light begins to blink. Once the button starts blinking, your network settings have been reset.
Sources:
About the Author
Jennifer Smith is a technology writer for HP Tech Takes with more than 15 years of experience covering consumer technology, PCs, gaming, productivity, and emerging tech trends. She specializes in translating complex topics into clear, practical advice that helps readers make confident technology decisions. Her work focuses on helping everyday users better understand devices, software, AI tools, and digital experiences through approachable, research-driven content.
